Yes, agree.In Magma's DCB layout, wouldn't it be better if the positions of the transformer and PS board were interchanged? Wouldn't that result in a shorter path for the DC to the main board?
It does not make sense to me. it okay, if you put twisted wires.The DC leads are barely 6-8 inches long from OPS board to DCB1. I can use thicker gauge silver-coated copper if that helps reduce potential losses across this distance.
Anyway, on larger holes, solder pads on copper plain have heat spreaders around it. Its minute gap with surroundings connected with smaller tracks. So observe they have always finite contact with surrounding and thus in any return path of current.Edit: on second thought, inserting a larger lead into the holes in the DCB1 board is not possible unless one substracts some of the strands (and defeating whatever advantage the larger lead may provide). Of course one can solder the lead onto the board without inserting into the lead hole. Looks a bit untidy, but I have done it when adding power rail caps.
I am not happy with these "EMD" r-cores.Edit 2: if the holes for mounting the R-Core and OPS board have not been already drilled, swapping their positions makes sense. I guess the present layout follows the usual practice of having the transformer closest to the IEC socket (though I admit there's no real advantage).
I am not happy with these "EMD" r-cores.They are not true to theoretical R-Core. Ideally they should be build like - primary and secondary on separate bobbin around core. But EMD guys are dividing primary and secondaries on both bobbins, overlapping them.
So its another step brother of toroidal.
. Need to take this with them.
Joshua, finally what happened to your Salas DCB1?
@Om: bottom of transformer has 2 layers of soft rubber so I utilized the one meant for bottom at the top![]()
Thanks for the information.
Still last but one, picture showing metal plate upside down.
