Sideloading Equalizer APK on Eversolo DMP A6
corElement
gurgaon / Delhi / NCR
Has anyone here tried sideloading android APK on their evesolo a6 device? I am considering sideloading an android equalizer app to play around with on the a6.
The only place I found some instructions were this
And this
I don't know if this is correct or not but wondered if anyone had tried this here.
And this
I installed Simple Radio Android apk, it works perfectly.
And this
The new update has arrived with an inbuilt equiliser in it. That is if you are using the inbuilt DAC.
