Sony 42W900B vs Samsung 40h6400
Best Smart 3D LED TV
  • Total voters
    5
goelmanu15
India
Hi All,
Can anybody please let me know which SMART 3D LED TV from below is the best in terms of 3D Picture, Color reproduction, Picture quality, Sharpness Contrast, Deep Black, less Black Uniformity Problem, Smart features and Smart Remote.
1. Sony 42W900B
2. Samsung 40h6400
Note:- Budget is not a problem and anything under Rs. 1,000,00.00 will do.
Also please If anyone can explain to me all the Technical features that these LED TVs are having and is the Quad Core Processor on the Samsung TV any good in the real.
I want to know the absolute Best LED TV for the price range.
Sony would be my choice.
If you want to spent Rs. 100K for led tv then you may think for an another option that is 55" VU 4k UHD Led Tv. Performance-wise it is at per with Sony and better than Samsung. Some of our FM have owned this TV and they are fully satisfied with it. Before investing plz go through this http://www.hifivision.com/television/58210-vu-4k-uhd-television-installed.html
And also you will get an additional 2yrs. warranty by spending an extra amount that is 10% of MRP.
