Speaker Cable running short: Solutions?
samgurung
Shillong
My 14AWG speaker cable is running short by about a metre. Is there a proper and neat way i can extend the cable without compromising quality? Currently the cable is terminated by nakamichi banana plugs.
Thanks!
Are your cables expensive? Worth the effort?
Or unremovable?
Wikihow and hometheatreshack suggest using wire nuts (and other methods). I think it should work.
Thanks!
Not without compromising quality , wiser to sell it off and get a different cable as any connections leading to shorting could ruin your amplifier. Not worth the risk
Thanks!
Are they expensive? If so, sell them.
Get lampcord a.k.a electrical wire (2.5 sqmm or 4 sqmm).
Bare wire the connections.
Shop for new cables if not satisfied.
Raghu
Raghu
I agree with Raghu, I have been using Havells 2.5 sq mm wires with my Marantz and Taga speakers. I'm satisfied with the SQ and once everything settles down i.e. burn in period and final speaker placement, if I'm not satisfied I might change them. Right now no issues. There is no harm in trying. In my case I had quite a bit of cables lying around after my house construction. So used them..
