reubensm
I was one of those guys who really did not care too much about stories that cables make a significant different to SQ. Moved to Python interconnects primarily as I did not want to use el-cheapo local cables. Now, while moving around things in my new listening space, realized that I need longer speaker cables. Now, I was worried about increasing the length of my speaker cables (to 14 metres) so did a lot of research online. Finally, I decided to try a few things, increased the length of my existing speaker cables (ordinary OEM cables with came with the BPL floorstanders), thought there was a bass fall off. Tried electric wire (used for my home's electric wiring). Still sounded the same, quite disappointing. Finally a friend told me to try high quality 3-way ribbon cable, normally used for submersible pumps. An engineer friend helped me with the calculations and I decided to buy 30 meters of this cable with the following specificaitons:
Number of cores X-cross section (no. x sq mm): 3 x 2.5
Outer dimensions (mm x mm): 13 x 5.9
Max conductor resistance at 20 deg. cel. (ohm/km): 7.41
Current carrying capacity at 40 deg. cel. (amps): 18
Cut the cable into 2 pieces of 15 metres each, used the red and yellow wires (left the blue one out) and wired my speakers to the amp. There was an immediate change, the bass was back, speakers sounded loud and sensitive (as usual) but the marked change was with the imagery. When I closed my eyes and listened (from a central position), if felt like I was in a concert hall, listening to an orchestra. The interesting aspect is that one could enjoy the imagery even if the listening position was changed off centre, beside one of the speakers. I am very happy with the results but think a little more can be done. The room currently has no furniture, just empty. When furniture is added, a bit of the spacious effect (marginal echoing) will be lost but overall, the imagery should be more of less the same.
