speaker for yamaha 863
Rakesh
noida
hello, every body
please suggest appropriate speakars for avr 863 which i bought from singapore in 45 k ( thanx to venkat & Nikhil for helping me to buy the system)
hello, every body
You have many options from wharf to Tannoy,Mordauntshort,Polk(can sound little harsh)QUED etc.
Hi Rakesh,
We could help you better if you answer these questions:
* What is the room size and shape?
* Is it a family lounge, or a dedicated HT room?
* Is this for movies only, or also for music?
* What kind of music/ movies do you like?
* What sources would you be using (DVD/BluRay/AudioCD/Cassette/LP Records/Cable TV)?
Thanks,
Sharad
Please suggest floor standers to pair with yamaha 863.
I have auditioned Dali Lektor 6/MS Aviano 6/Wharfedale 10.5 and 9.6/Polk Rti/Tannoy F1(couldn't get F3/F4)
My Room(dedicated basement A/V) is 22x9.
I am looking for a 5.1 setup..
Also suggest whether I should mix and match speakers for rears/center and subwoofer of stick to the same brand.
My primary usage is 50/50 movies-music, but I prefer vocal clarity more instead of bass.
Also I feel that I cannot trust my ears, as some music CDs sound good on one pair, and some other sound good on another pair ( I say this because I found that vocals/classical were really clear on the 10.5s, but found that the background tablas/instruments were really great in 9.6)
Please suggest some technical aspects related to pairing with A/V receiver such as brightness etc so that prolonged listening does not sound harsh to the ears..
Thus far my list is in the following preference order
1) 9.6 Wharfedale
2) Dali 9.6
3) Tannoy F3/F4(not auditioned, but what I heard from F1 was really good)
4) MS Aviano
max budget:
fronts: 40k
5.1 complete: 1L
Please help..
Any of the speakers you have auditioned will work with the Yamaha. So the best is to trust your eras and buy the ones your ears like best.
hi venkat,
thanks..
one of the factors which i cannot judge would be..
please provide ur comments on this..
