Speakers for Marantz SR5006 AVR?
paramesh
Hi All,
thanks for giving your valuable information to choose AVR.I bought Marantz SR5006 AVR , 6 months used.pls suggest tower or bookshelf speakers which are suitable to my avr?budget is around 40k.I am waiting for your suggestions.
thanks
Go for Paradigm Monitor 7, just heard this at Kittu's place and itz driving good. Suitable for movies and also music.
Hi All,
thanks
Audition Mission MX speaker range with Marantz receiver & you will be pleasantly surprised ....
You also have Sonodyne / Tannoy / Wharfedale FS for < = 40K budget....Few other brands have been already recommended..
Audition as many speaker as possible & then pick the one which you like...
I am using Quad 12L2 with my Marantz M-CR603. Pretty good. You may want to check these out. They go well with Marantz.
I have not heard the combination but for music I feel Klipsch would match Marantz well for movies...as also Monitor Audio
We liked 5006 over Denon 1912 for movies in Mumbai HT meet where it was connected to Klipsch in wall speakers.
I think so Klipsch is costly and it cross my budget also.I want some more bass (with out boomy) from two tower speakers .
Hi All,
today I went to see the Definitive technology 8series sepakers,they are good for marantz.sound is details and subwoofer is too good.every thing is fine,but cost is 74k :) .
may I knw why I am not getting any reply for my thread?.
any suggestion .
any thing wrong :)
Try listening to as many speakers possible for your budget & then choose the one that you can afford & which u like...
i believe u have already heard Sonodyne..Did you try Tannoy / Wharfedale / Mission ?
I heard Tannoy v4.it is fine,but I am looking for more bass. :)
today I went to demo of Paradiam monitor 9 v7,it is giving too much treble,I can't able to listen for 2 min .then after I went to see EPOS EPIC 5 (suggested by FM member kittu),it is too good,I like EPOS sound,whatever I played in Paradiam, same songs played by EPOS.so much different :yahoo: . I want say thanks to kittu who suggest to see this speakers .
