Speakers for Nuforce DDA-100
onyxgaze
New Delhi
I was looking to select optimum speakers for the Nuforce DDA-100 digital amp.
I read this amp requires high efficiency speakers greater than 88 dB/W/m?
Speaker choices which I was given are B&W 685/ Goldenear Aon3/ Amphion Ion+.
Any advice would be welcome in making a choice.
Thanks in advance.
Excellent, then you need to give us your budget as well as preferences in music, whether you are looking for a FL or BS and room size...
If you want to listen to the Harbeths, then you are most welcome to bring your amp to Faridabad and listen for yourself....
