SPKR Package for RX-V565/665
vikram_kp
could anyone recomend a suitable speakers for RX-V565/665 receiver from yamaha?
My room is 220sqft carper approx.
Budget for spkr package is 30K
VKP
skumar
Hyd, India
VKP
Assuming that you are looking for 1 5.1 (HT) setup, try Energy Classic or one of the Wharfedale packages. QA 5.1 might also be an option if you stretch your budget a bit.
If you can afford to spend more on the speakers later, you should consider going with a 2.0 set now (PSB Image B25, Usher S520 etc.) or a 2.1 (Wharfedale 9.2+SW150) and add the rest later.
sud98
bangalore,india
The QA 1010 series package is about 45k. Check out the speaker price thread in the speaker section and you will get more updated prices as well as other brnads to choose.
vikram_kp
any idea how good Paradigm CT90 works with rx565? is it a good deal for 35K for spkr package without cable? hope rx565 works well with video & audio without delay, cutting etc
