Step Down Stabiliser for TV
travel_living
blru
Hi There ,
I am planning to import XBR-65X900E TV from US to India. Their Power Specs says - AC 110-240V, 50/60Hz (USA / Canada AC 120V, 60Hz) DC 24V.
Do I still need to buy Step Down Stabiliser to control Voltage? Any expert advice.
Cheers.
I also want to import a Sony TV from the USA! Do you know how you will import it? What's the cheapest and safest way possible?
55X90F is only Rs.1,00,000 in the USA whereas we have it here for an unbelievable price of Rs.2,40,000
Hi There ,
Cheers.
I got a quality transformer from Aulten, my requirement was for USA 120v AVR, so had a long chat with Aulten executive, just to confirm the product compatibility and quality, they are very good at providing resolution and transformer quality is excellent.
You can contact Aulten voltage converters at 9811597709, you can chat with them on Whatsapp also.
Aulten 1KVA 800W 220V to 110V Step Down Voltage Converter with Universal Socket (White), this will do the job, I am using the same with no issues, no humming, no heating.
Hope this helps,
