Stepdown for AVR
yup....7005 n PSB T6
Waiting for PSB, the color of my choice is at customs apparently :( ....waiting to be cleared. Got my AVR on time.
For now using a couple of energy speakers...from Take 5.1 old version
no one knows where to get the step down in mumbai?
Finally i found a dealer for isolated type step down and the brand is vertex ( kittu had provided the link above for same company's product which has stabilizer as well )
Alakrity Tech, Cell # 9820422120
He gave me quote of 7K INR for 1kv isolated step down and 5.5K INR for automatic one.
I think the isolated one is very expensive ( 1kv is bet 6.5-7K INR) while we can get automatic one of a good brand like Maxine for about 3.5K INR
Naren
@naren
after some enquiries just now which my friend found thru maxine only
theres this Skyking agency in Lamington road which will give an Auto step down 1KVA for rs 1800 .note its not isolated and of EATA brand
but iv seen some people say on forum that isolated is not required and they are doing fine with auto .
and the pricing should also be around 2k for 1 kva not higher
i also have been using this one for my Xbox from Japan since past 4 years without any problems.not sure about specs
i suppose the 1 kva one will be like this only
Yup, that's pretty much how is looks. It's just a tin box with a power on off led in front and switch at the back with just one power outlet plug....I got it for 3100
So no fuse or mcb( auto cut down switch) ? and how many KVs is your step down and which brand?
Forgot to add, one slot for the fuse...and one spare fuse as well. Mine is same as Jatonmalhotra's ..... Guru brand. Home made :) 1kva
i have bought the same one i mentioned above for 1800 .
no issues whatsover ,rig set up posted in receiver section
Crosspost from http://www.hifivision.com/audio-video-accessories/15235-power-games-servo-stabilizer-cvt-online-ups-38.html#post300622
I have a Yamaha DSP A1 (500 W) and a Hsu Subwoofer Amp (1100 W) both requiring 120v power supply. I wanted to buy a solution that would condition the power, have surge protection and also step down to 120V. After some research I located a small company called MAKSON ENGINEERS in Borivilli, Mumbai. (Pls PM me for contact details). It is a small but very professional setup. I visited their shop floor. It was very clean and dust free, open chassis showed well laid out components and interacting with their engineers I felt confident they knew their job well.
I initially wanted to buy a CVT, but after describing my requirements and taking their advice, I finally got a 3 KVA online UPS and a separate isolation transformer (step down). Since I did not go in for frequency conversion (they could do it too, but too costly), I made them give me 3 tappings for the step down transformer, at 110, 115 and 120V. This is because I read that if your amps run hot in 50hz, then reducing the voltage a bit helps.
The key thing for me is that, I found a company that was willing to produce a custom built solution for me based on my requirements, with good components and good quality. The final body finish is not as shiny as some branded products, but I'm very happy to know the insides are well designed and that I can call them any time I have a problem or needed modifications. For eg: they can change the UPS parameters (output voltage etc) by simply tuning it with a software from a PC.
I've used the product for a month now and so far it works very well. The step down transformer is absolutely silent, no hum at all. The UPS is silent, but the fan is quite busy. Every time the load goes up, the fan goes into overdrive. So its not good to keep in the same room as the AV equipment. I installed it near the mains in the line that goes to the AV room.
The total cost came to Rs 29,500, which I thought was not bad considering both UPS and the Isolation step-down transformer are rated 3 KVA each.
If you are in mumbai and looking for a custom solution for UPS, sbatilizer, step down transformer etc, I would strongly recommend that you talk to MAKSON too.
regards,
Dovin
ps: Both my amps have no issue at all with 120v/50Hz - Absolutely no hum or running hot, so the 3 tappings were not needed in the end.
