keith_correa
<snip>I auditioned this amazing book-shelf speaker set today. Monitor Audio GX 50! It was paired with NAD C-326 and REL Acoustics T-zero subwoofer.
I've almost made up my mind on this combo. This is THE kind of sound I was looking for. Fast, agile, tight! The high frequency response is amazing, the sounds in psytrance sound perfect! The midbass is crisp and accurate.
The REL subwoofer blends absolutely well with the speakers. The bass is not at all boomy.
All in all, I'd very happy with this setup and would finalize the same tomorrow or day-after.<snip>
Just add it to your short list. Then listen to other speakers. Keep adding/eliminating from your shortlist. In the end you will have just one on your list and that is the one to buy.
