Stylus for shure m55e cartridge
visvan1970
india
Dear all, i am looking for a suitable stylus to match M55 E CARTRIDGE. Is it available in Chennai.or can i order online. Any idea of price. Thanks. Visvan
btw any idea whether N44-7 Stylus will be compatible with M55-E cartridge. Is it better than N55 E Needle.rgds.visu
From what I recall the Shure M44 was below the M55 in the Shure cartridge line up.
I am not sure;) if the N44-7 stylus will work in the M55 body.
Shure M55E.. just how good were those? - SH Forums
You might find the above link useful.
Rajiv
Hai visvan,
If this is your TT you can change the cartridge to AudioTechnica AT-91 . One more better option would be to change to Shure 97XE which will give better SQ.
Hope this helps,
N.Murali
Hi! I have a Sony TT Model PS 434. I need to change the cartdrige and I am not sure if I can get one in Gurgaon/New Delhi. Keen to hear my old vinyls again. Dr. Hariharan. Suri
