Subwoofer and rear surround speaker suggestions ?
VipinS
Rajasthan India
Hey all ,
I am making a 5.1 home theatre setup for my bedroom size 15x16 feet,height 12 feet . My movie :music : gaming ratio is 50:40:10.
I have finalised on Denon avr x1600h with Jbl stage a130 Bookshelves speaker and stage a125c centre speaker .
looking for a subwoofer under 40k max budget .I have shortlisted-
Polk audio hts 12
Jbl stage a120p (same series as LR and centre )
Klipsch r120sw (not sure if it would be in my budget)
any advice ?
also any suggestions on surround speakers to complete my 5.1 ? Polk audio owm3? Or any other wall mounting speaker ?
Thanks in advance .
Note- I can’t keep the sub woofer far from the wall .
Hey all ,
Polk audio hts 12
any advice ?
Thanks in advance .
Add BicPL200ii to the list
Polk audio HTS 12 is perfect fit in your budget & also sounds great.... using since almost two years..... it's port is downside so no worries you keep anywhere...
For rear surround go for Q Acoustics 3020i..... perfect fit & performance. Have paired with Denon x1500h
Hi, how did your setup turn out? I am upgrading my 5.1 setup with JBL stage A120 bookshelf pair for the fronts and Stage A125c center. Yet to wire everything up and test them.
How are the stage speakers?
