subwoofer selection
nsr1969
Kindly suggest a ggod subwoofer within 30k for the following set up
Room size 30 *17*12
Amp - Denon 2105
Front Speaker - Jamo E 680
Centre n surround - local
Check out the Polk DSW 600 PRO...(under 30K). However, if can boost yr budget to about 35K, then check out the Wharfedale SW-250. Key spec to look for is the +/- 3dB performance range of the sub, besides its musicality.
