Suggest car speaker for alpine CDE W235EBT to Dzire
arunmanjoor
Hai I am Arun from Bangalore. Please suggest speaker for my new alpine cdw235bt for my dzire. I went to EVO in cambridge layout he suggested the above system. He suggested cervinwega. In reviews I saw that it is good for bass. I like soft music. My budget is 10k for speaker.
Arun
@OP
TBH, there are many reputed speaker brands available now and in your budget you should be quite satisfied. Do look at some previous threads for choices detailed, at varying budgets. Hertz/ Boston Acoustics/ Rainbow/ DLS/ Focal/ etc...
I run an Alpine/ Crunch Audio/ Boston Acoustics rig in my car, and for a value setup really enjoy the sound. It has been a few years now though and my sights are set on a better setup, at a different budget of course.
Cheers!
Do you have plans to install amp and sub as well? If not i suggest you to install a 2 channel amp along with the front speakers. Amp is needed especially if you are running a diesel vehicle.
No plan to install sub. Why amp is necessary for diesel vehicle? My vehicle is diesel. If so required which amp is good and how much it will cost?
The floor noise will be higher as you pump over 2k rpm. Hence you will try to compensate by pumping up the volume. An amp will provide enough juice there. The SQ will be much better with amp. Something like Focal Solid 4, Hertz HE4 should suffice. HE4 costs 7.5k. Solid 4 might be around 12 to 14k. I am not sure about the 2 channel Focal Solid 2. You can check with some of your local dealers.
Try PHD speaker .you will enjoy the music without sub smooth soft without ear fatique even in high volume for long time.iam ahappy owner of PHD
+1. I have auditioned 2 or 3 PHD systems. Excellent midbass and detailed highs. Very affordable price.
