[Suggestion] Best HT Under 50k, and Best Soundbar under 25k
ashwarsadh
New Delhi
Hello Everyone,
I have 1x Samsung 8 series 55" 4K 3D TV and 2x Samsung Series 6 48" TV. I need to buy HT System for all 3 of them. I am a novice user based in Delhi.
Actually, I had setup internal wiring in 4 corners of my all 3 Living Rooms during construction(generic Copper+Aluminium coil cables)
Now, I want to install HT System of upto 40k - max 50k budget for my main living room it will be used for 75% movies, 25% TV Content. I need to mount these speakers .
I have read alot on this forum, and found that Yamaha YHT299 is really good.
Regarding other 2 living rooms, usage would be low (50% music 50% movies)
I was thinking of going for a soundbar maybe, as I am not sure about my internal wiring, as electrician has left hidden 1 wire inside the wall, So, I need to search for the lost wiring.
If soundbars are really bad compared to 5.1 systems in same price range then I can go for the wiring troubleshoot.
Kindly Suggest me Best HT System for upto 40-50k max
Also suggest me best Soundbar upto 25k or if HT Systems are MUUCH better than soundbars, then best HT System for 25k.
Based on the available space and requirements, go and audition the available systems in the market and shortlist what appeals to you in appearance, performance and budget....accordingly then finalise.....remember you are the one going to use the same at home and not us so it should be satisfying your ears.......there is nothing best or worst systems...its all personal choices based on performance and budget......very few see system benefit the technical way and venture to spend more on hi end stuff....all the best
