Suggestions for front firing Atmos modules
Home Theatre Systems
sunster
Mumbai , India
I have decided to go with front firing Atmos modules to be placed on top of the front speakers. Any suggestions ? I have a quote from Dali alteco and klipsch R14 SA.
elangoas
Madrasapattinam
Upfiring module seem to be a compromised solution.. In your earlier threads / pics of your room, saw you had false ceiling.. Not considering in-ceiling speakers?
Any suggestions ?
Sonodyne Sonus 3540 is an other in-expensive option 15K a pair i guess.. ELAC too has similar offering.. You may check that as well..
sunster
Mumbai , India
I won't be able to do the inceiling and height modules. Also will need and avr uograde which is a huge budget. Will just go with these for now which will work with my denons
sanjivnayak
Bhubaneswar
For inceiling speaker why should you upgrade AVR. Could not understand.
sunster
Mumbai , India
its not just the budget...the wife will NOT allow any kind of breakage or casing patti or anything that spoils aesthetics. ...so no go
rpmahale
INDIA - Mumbai
It's better you go for front height and rear height speakers for Dolby Atmos setup for minimum damage. Small satalite speakers with mounting options will work fine like Polk OWM 3/5, Definitely Technology ProCinema 600/800 or Mythos GEM XL are some of the options.
sriram_shol
Coimbatore, TN
Yes, also this would help to future Auro 3D upgrade in case of Front Heights and Rear Heights.
I am using Sonodyne SONUS 3540 for the front heights and I am happy with its performance. Even though it is not 100% Atmos, you can still experience the ceiling effect effortlessly.
sunster
Mumbai , India
Auditioned the upward firing Dalis and inceiling paradigms. Day night difference. I shall be going with Paradigm inceiling 2 speakers with my existing avr.
annapl
PUDUKKOTTAI
5.1.2 is more than sufficient to have atmoss effect coz most of the atmos encoding is in 7.1 i,e 5.1.2
ItsMe
Kerala
You can flush mount the inceiling speakers, which will blend with the ceiling. Search for flush mounted inceling speaker pics, and demo it to your wife :) . Anyway, upfiring speakers are to be ignored if you are serious about atmos
elangoas
Madrasapattinam
I don't have good understanding of object based.. But, atmos isn't limited to just 2 overheads..
The overhead content is not channel based like we have had for standard Dolby 5/7.1.. Once the overhead speaker are located, AVR remaps the atmos content according to the layout. 4/6 overheads..
annapl
PUDUKKOTTAI
but the source content released is channel based and its written as 7.1 dolby atmos to my knowledge atmos is a innovative idea that involves listeners to experience sound from above
ambient sounds that envelops us in real world
when a speaker is placed above head this creates that effect but IT FEELS DAMN GOOD
D
Deleted member 38504
Guest
Where did you demo the Paradigm? And if I may ask, how much are they? I’m also looking for in ceiling speakers for an atmos setup. Thanks.
