suggestions for Good Bluray player
idlefriend
hyderabad
I am looking for good bluray player which can give 7.1 channel out put and can read all formats.Please suggest good one.
Thanks in advance.
Based on your budget, you will need to check players and read the specs....
Brands within 10k range would be Sony, Samsung, LG, Philips etc.
Brands above the 10k would be high end models of Sony, Panasonic, Pioneer
Most expensive ones are Marantz, Denon and Oppo.
Pioneer BDP180 should work just fine.
If it is out of stock, possibly there could be a new model coming...if you are not in a rush, wait , else look at some Philips models..or panasonic
how is the sony BDPS6700? Also are most blu ray discs region free these days? will region free discs play on a region A player?
I've been trying to get Pioneer BDP-180 in Bangalore for almost 1.5 month. But everywhere it's out of stock. Now, considering Marantz UD5007 as fall-back if I don't get Pioneer BDP-180 in next few weeks.
Now, UD5007 is almost twice the cost of BDP-180. Is there any other alternative in between? Sony UHP-H1 or Yamaha BD-S681 etc are not available in India.
It's available in amazon.in
Sent from my XT1562 using Tapatalk
