Surrounds - Mono , Bi, Di
Rajkumars
vizag
Hi all .... a quick question ....
For 5.1.2 ... Atmos ....
Is Rear Surrounds better or Side Surrounds ....
If Side Surrounds - Monopole or Bipolar of Dipolar
If Rear Surrounds - Monopole or Bipolar of Dipolar ....
To me side surrounds are better, diopole/bipole/BS doesn't matter much.
You can select depending on your choice
For sides strictly use monopoles and if back then go for dipoles if near by wall seating. I tried both and hence suggesting
But for sides I am using monopoles .... It gets too localized and the person sitting near to it gets his ears killed ....& The effects are Missing
Depends on your listening position.
If you are sitting near the back of wall , then Bipolar works better.
If your listening position is middle of the room , then monopole side surrounds better .
Personally i felt monopole side surrounds works good and suffice for most of the listening position in the room.
Am sitting near back of the wall ....
Is side bipolar better or rear bipolar ....
I have Kef Q950 as fronts, Wharfedale Diamond 225, 220, 220c currently ....
Marantz SR 5013
Which brand/model bipolar speaker is best for rear ....
I like good old surrounds. With tiltable wall baracket so that you can get the best direction for sound dispersion
