Tubes Amp --Specification before buying
roseboy24
New Delhi
Discuss Here Tube Amps Receivers specifications /Query /Performance based on below specs.....:clapping:
Balanced output ?
Output voltage ?
Frequency response ?
Distortion ratio0.01% ?
Signal to noise ratio ?
Tube Complement ?
Sound track separating degree: ?
power consumption ?
weight --
Balanced output ?
Output voltage ?
Tube Complement ?
power consumption ?
weight --
Vikram
Such a de-constructionist approach is not going to be fruitful. You need to hear something you like, then hear something even better and realize what you liked originally wasn't the great one after all, then having the intellectual muse about whats inside and its parameters makes sense.
Gobbie ,
Thats what we are doing here .... for discussing users for there taste and likes or dislikes ....we are here understand each and every specifications makes diffident impact . different sound .
whats impractical ....
Hello Vikram,
Specifications in audio equipment reflect just engineering guidelines. Unfortunately, they have no correlation as to how the good the equipment sounds when reproducing music.
The only judge there are your ears - you have to listen to find out. And do start thinking in terms of music systems, rather than just individual components.
Viren
Dear Viren sir ,
Thanks for reply , I will surely plan soon for listening your tubes Amps which is appropriated by thousands of users and best part iam your neighbor stayed at B block SV.......
regards
Vikram
Vikram
To add to Viren's point, specs are like the length of a car-you can have a car of 4.2-4-4 m length which could be a Swift DZire, or a Toyota Etios or a Corolla or a BMW, going by the length all are almost equal, but in fact we all know they are not. The same applies to applying technical specs like weight and power consumption to a tube amp.
