upgrade for dts master audio
COOLVIKAS
delhi
[B]hi
i need advise is it worth to upgrade avr only because of dts master audio formet im using denon 3805 with jbl 5.1 please help
[/B]
No.
You'll not find it worthwhile to upgrade just for DTS master audio. Denon 3805 is capable enough is excellent for Dolby Digital and DTS.
If you need to connect video through HDMI, which it (denon) can't handle, an upgrade will be required.
Kindly do not post in large or bold letters.
hi
You should have written the post in normal font.
DTS-MA is only beneficial if you have quality speakers. JBL 5.1, i m not sure which model but i think it wont make much of a difference.
