Few months back when i started my journey in projector world , the area was very new and did not have much idea on how these would actually look and perform.
So played safe and went with a basic cheap projector.
www.hifivision.com
Though it was nothing to write home about but most importantly it introduced me to concepts and what to look for and how to decode several specifications which were very alien to me at that time.
Though it has several limitations but was still mostly happy with the usage I was having and also proper upgrade would have costed a lot. So there was no plan to upgrade atleast till a year or so and was instead priority was to upgrade my audio system and old plasma television.
By chance couple of months back i got chance to travel to states and over there projector options are huge with very attractive pricing.
With my experience i knew I need a short throw one which can be installed and replaced as required in my living room. Other was that even 1080p resolution would be fine based on content i would be having access to, screen size and viewing distance.
Though ideal would have been a UST projector but even base models were stating from 1000usd. Then came across Optoma GT1080 Darbee for 650usd. It was having a bit higher throw ratio of 0.5 and no zoom function but was still fine for my usage so decided to get this.
I am using my existing 90inch white projector screen with and experience is very good. Pictures are crisp and clear and even in eco mode and reduced brightness visibility is good in dark room. With some ambient light also PQ is good just need to increase brightness a bit.
This model is smaller in size and comes with carry bag so carrying and storing it is also convenient.
Small issue is that with no optical zoom and lens shift have to to manually move projector while setting up every time but after doing it sometime its bit easier now.
Some snaps
Still working on proper setting with some experiment should be able to get some betterment.
Any suggestions on how to properly calibrate the projector so reference images which can be used.
Basic Start to Projector World
So, frustration kicked in few days back due to not able to finalize my HT speakers, confusion, and in-decisiveness ,needed to have something to keep myself busy, clear mind and take a break for a bit. Result was getting a projector. Though it was a impulse buy, a projector was always in plan...
Some snaps
