Using rj45 or internet cable as rca cable
rayvonnee
Kurla, Mumbai
I need to connect a subwoofer and my house is prewired with all cables but no subwoofer cable. I have a internet wire running and wanted to know if it is possible to solder rca plugs at each end and use it as a subwoofer cable as it is not possible to run a cable. Will it be fine if i use this?????? Thanks
The twisted wires still have too much capacitance I believe. Better buy a sub cable.
G0bble
I am offering an unconventional solution. You may or may not like it, but here goes.
Use a wireless transmitter/receiver pair. I am pretty sure it will be cheaper and more elegant than any run long of any decent RCA cable.
My 2 Paise.
Electrically you can CERTAINLY use the Ethernet cable to carry signal low level signal to yr Sub.
The only concern you will have to check for is whether there is a Hum pick up by the Ethernet cable since its not shielded. You will know only by trial.
The Ethernet cable has 4 Pairs of wires in it. You can use any 1 pair.
All The Best !
