veneer availability
krell
Usa
hi,
good morning to all.
i would like to re veneer my Yamaha NS1000M speakers.
the original one is black ash veneer and it is very very bad shape.
i would like to strip it completely and redo the veneer job.
any suggestions where can i buy the veneer sheets,preferably american walnut or cherry or mahogany.
preferable city is Hyderabad, but i can travel to Bangalore, Chennai etc.,
thanks in advance.
hi,
thanks in advance.
Check here, they may have a dealer/distributor at your place:
home
Thanks,
bibin
Veneer is generally of two types, one is like a sheet of paper or piece of cloth, dont know the technical name. the original veneer is manufactured in this way only.
the second one is the one sold by most veneer companies in india. the paper veneer is pressed on 3mm ply and then sold in the markets. typically carpentars use this type of veneer due to ease of use. As far as my knowledge goes, century ply sells the best of the veneers in our country and they have wide numbers of distrubuters/dealers in india. you can get it in your town. there is no need to travel for this.
Not sure if the paper veneer is available for retail sales in our country or not. further it might be slightly difficult to paste the same on the surface of a speaker for an ordinary carpentar as you might need specialised tools for good finish.
hope this helps in some way.
I had mentioned in a post about a year ago a vendor called Jacson in Bangalore who have an excellent range of veneers.
thank you verymuch for your response.
i tried the search function,but failed to find the thread.
is it posible to provide the mobile number of the dealer or contact info?
thanks
Amit
Veneer is the very thin variety, and is very definitely available in India.The 3/4/6/12 mm plywood with a thin venner stuck on it is called decorative plywood, it is not veener.
thanks a lot.
i am searching for veneer of 10mil or 0.8mm thick size.
thanks for your inputs and your information regarding the seller.
regards
krell
