Wall Mount Brackets for Polk RTi A3
HTuser
I am looking for wall mount speaker brackets for Polk RTi A3 (bookshelf) speakers.
I am planning to install them as surrounds and would like to install directed to the listening position.
It has the option of wall mounting on nails, but it will be straight-line and not directed to the listening position.
Normal satellite wall mount brackets won't work due to the weight and size of this speaker
Dimensions: 14.75" (375mm) H x 8.58" (214mm) W x 14" (356mm) D. Weight: 16 lbs (7.26kg).
If nobody makes mount for this kind of speaker I am also ok for custom. Pls give me details of any dealer/distributor/vendor who can help
Note: I shifted to a new flat, I am yet to install the surround speakers.
Thanks in advance
