Wall mount for SVS Prime Satellites
debojyoty
Hyderabad
Can anyone please suggest what wall mount can be used for SVS PRIME satellite speakers?
The speaker will be mounted on the left and right wall from viewing position and the wall mount should have tilt and swivel options.
Svs prime satellite has keyhole at the back.
Debojyoty
Debojyoty
Check the manual of the SVS Prime Satellite as in what inserts / Key hole options are available and then check on Amazon for possible stands...also check locally with dealers.
