What are the best speaker cables under ~300-400$
Gsomin
United States
Dear community,
I am looking for good speaker cables for 15ft, preferable 18ft. Hope to stay under about $300. Currently using monoprice cable 15ft 12AWG Pure Copper Hi-Fi Speaker Cable with Solid Brass Interchangeable Terminals-Black.
I was looking at Nordost in particular (white), but I ma not sure if they are worth the hype.
Thank you!
What speakers/amp are you using now ? speaker cables are the last cables to change in the "Cable Hierarchy". you may get a better benefit with Interconnects .
Additionally speaker cables are a hit and miss..works for some and does not for others hence never buy blind without having heard it in your system and validating any effect. But as a principle a Well made Copper 10-14 gauge cable will rarely do any wrong
