What is the code for Tata Sky HD set-top box on Logitech Harmony ??
Spidey
India
Hello
Anybody used Logitech Harmony with Tata Sky HD.
Is there any new code/model no that i can feed in setup of the Harmony ?? It selects TataSky as manufacturer and asks for model no..
but the HD box shows no model no.
Pls explain if anybody used it.
thanks
Spidey, Were you able to find the model number of the tata sky HD box ? I need for the same reason. Just got the manufacturere name - Kaonmedia, no model number on the box.
Please let me know.
thanks
Sachin
hi
Logitech accepts Tata Sky as a set-top box brand.
But there is no further division in models like plain or HD.
Just entering Tata Sky also works.
but model no of HD box is unknown.
thsnk'
Model number is mandetory field. So i tried the example model number next to the box (i think this is of the old thomson boxes) and it worked !
thanks
Sachin
I'm using the Harmony One with the TataSky - no probs. Spidey, if you still have a problem, just come across to my place in Utopia, and bring your Harmony, we can set it up.
Viki
I have successfully added TATA Sky HD+ in my Harmony one remote. You can find the model number at the bottom of the box. IT is not by Thompson. Brand name is Pace and model number is TDS865NTS. You can easily add this in Harmony one.
Did you get plan and organiser buttons? I did not get it.
As a last resort, you can always make the remote "learn" from your existing TataSky remote. Assuming, you still have the original remote.
