What is zone 1 and 2?
paramesh
Hi All,
can any one explain what is zone 1 and 2 in AVR?Yamaha 671 has zone1 and 2.what is the use of it?.
You can listen music simultaneously in two different zones (i.e., rooms). Some systems even allow different source to be played at each zone.
My confusion is,let say we will take 5.1 system.here what is zone 1 and zone 2?
I am new to HT systems,thats why I am asking,dont mind if it is repeated thread .
An AVR with multiple zones lets you simplify your life without having multiple amps all over your house.
Scenario 1: You want to set up a dedicated theater in a room, but want to do more common listening in your living room.
Scenario 2: Your watch movies on your 5.1 system in your living room, but want to setup a two channel system in bedroom for late night listening.
Scenario 3: You want to set up a good two channel system with higher quality full range speakers alongside your multichannel setup. or want to dedicated higher quality speakers for two channel listening.
A good AVR can be used in all the above scenarios to setup a good system without stacking components over components all over the house. You can designate your living room as Zone 1, your bedroom as Zone 2 and so on. Possibilities are endless, depending on the way it is implemented in your AVR.
Hey Suresh,
AFAIK the Zones are not for the regular single location setup ... the zones are given with two different outputs.. If you have a Zone 2/3 along with a 5.1 channel output then at the rear of your receiver you would be able to see another set of speaker outputs tagged Zone 2/3
These outputs are not a part of your main 5.1 atleast.. sometimes there are zone 3/4 even. in the pic observe that there is a facility to setup a 7.1 with an added Zone 2 & 3
As ukjeyaraj has described: some AVRs can play different sources even..
Some of the features for Zone supportive AVRs are
Versatile Zone Control
Zone 2/Zone 3/Zone 4 on/off and control on front panel
Zone GUI (song/station select, album cover art display, zone tone controls/Zone balance, short message)
Zone video assign (Zone 2/Zone 3/Zone 4)
System Backup / Recovery function
Multi-channel output in main zone plus 2-channel HDMI output in a second zone
Zone MONO, Zone volume and tone controls
Party mode
If you are not sure, don't bother about it. It's a serious advice.
Just hook all your speakers to the indicated connectors on the AVR and you will be good to go. Most AVRs come preconfigured to use Zone 1 by default. And in simple setup, just hooking your speakers to the correct terminals is more than enough.
If you want to learn the concept, read my above post, as well as your AVR manual. If you are having trouble hooking up your system, let us know which AVR and speakers do you have and we can guide you.
thanks ranjeetrain for giving clear information regarding zones.
