Where can I get one of these in India?
gobble
Just came across this new product
TDK, a portfolio brand of Imation Corp., now offers two belt-drive turntables, model ETVT10101BLK and model ETVT20102BLK (350 each) with USB, plus a wide variety of new headphones. The TDK Life on Record turntable delivers the precision performance, has premium surfaces and features needed to truly enjoy the experience. This advanced belt driven turntable supports both 33 1/3 and 45 RPM playback speeds as the "floating" design isolates the platter and needle from external vibrations. An innovative visual 10 bar equalizer is embedded in the gloss black surface while the integrated pre-amp, USB output and included software let you import/convert tracks to a PC in MP3 format. The universal tonearm connection works with virtually all stylus.
:licklips:
Belt Drive Turntable
USB Belt Drive Turntable:licklips:
The TDK Life on Record turntable delivers the precision performance, premium surfaces and features needed to truly enjoy the experience.
This advanced belt driven turntable supports both 33 1/3 and 45 RPM playback speeds as the floating design isolates the platter and needle from external vibrations. An innovative visual equalizer embedded in the gloss black surface gives your music a visual heartbeat.
The uniquely designed and crafted tone arm with integrated surface lighting gives the freedom to use almost any stylus and cartridge from standard to truly premium through a universal connection.
Then the big question is if a 120 to 230v step-up will work without changing from 60hz to 50hz. Edit: The PSU pushes DC 12V (center positive). I guess any local PSU will do.
--G0bble
