Where to buy Shure V15 / M44-7 in Singapore
Hi Denzong. Thank you very much.
Actually, my cousin lives in Singapore and visits India frequently. I was initially reluctant to ask him to buy me a cartridge from there. After he came to know that I bought some cables from a US based member in another online forum 'Audiocircle' through another cousin in US recently, he has himself offered to help me to source anything from Singapore and agreed to bring me the cart.
Hope you can provide me where to buy Shure M44-7 from there. I'll pass on the info and he would buy it for me and bring it in person on his next visit to India.
Rajesh
Hi Capt Rajesh,
I have purchased AT-91 cartridges from the Following dealer, pl try your luck at :
Hinhuat Radio Company,
10, Jalan Besar,,
Sim Lim Tower,
#03-17,
Singapore 208787,
Tel : 62921183, 62926183, 62941692.
Hope this helps.
N.Murali
You can mail them too and you shall surely get a reply. I had contacted and got reply too. Google and u shall see their website which may have your requirements as the site gives all info
M44-7 or Mx97E are available right here in India. Call Neeraj in Delhi +919811089557 and he should be able to direct you to the nearest dealer of Shure.
V15 is a discontinued model (long, long ago). So the chances of getting a NOS piece from Singapore or elsewhere, is quite slim. But if you're hell bet on owning one, you should be able to get used ones from internet sellers. Also, there are specialists who selll stylii for the various flavours of V15s.
And when in Singapore, I wouldn't trust Sim Lim too much. My experience of purchasing stuff from there was not great. Look for specialist audio retailers.
Joshua
There are a few shops in the Adelphi Mall.. they sell a lot of records, and equipment there. Although, be warned, Singapore is avery expensive place to buy these kinds of things.. espcially records.. they were selling records that you can buy online for about $20 they were selling for upwards of $80.. although, I did splurge and buy a couple of pretty rare alternative rock records there once.
10, Jalan Besar,,
Sim Lim Tower,
#03-17,
Singapore 208787,
Thank you Murali. I tried calling them by pre-fixing +65 but the call is not going through. Are the Nos. correct? I'll pass on the info to my bro. Let's see.
I called the Sun Infonet guys in Delhi. I think Neeraj is their boss. They asked me to send a mail listing my requirement. Have done that; Let;s see. I'm not hung upon any cartridge. Any recommendations guys?
Hi Capt.
Went on Shure Website & got this website of indian distributor :
sungroup : suninfonet Pvt. Ltd.
Try sending them an email On: [email protected]
& see what response you get,
no harm in trying eh???
Here is complete list of shure cart's available
Shure Asia | DJ & Phono
FYI: the cart ur after is shown as a DJ cart
Thanks Denom, sent them a mail. Let's see. BTW I've also noted that M44-7 is a DJ cart; I was told that it is a compatible cart to the Dual and hence the interest.
BTW, can anyone suggest any other cart like AT / Goldring etc which could match the Dual?
Hi Capt,
Recd prompt reply from Neeraj of Sungroup. He put me onto the shop having ready stock of foll in mumbai, from where I just got the prices of foll:
M44-7 : 2800/-
M44-7-H : 4000/-
M92E : 2200/-
M97XE : 4800/-
Add 12.5% VAT to above prices for final price of each cart.
i think M44-7 is for DJ not for normal turntable......it is avilable with my friend cost around 2750 rupees..
Hi Denom,
Even I got a mail from him. I asked which cart would suit the Dual. I'm quoting the contents of the mail for the benefit of others who are on the same boat that I'm in. Now the ball is in my court. Will have to check which one would fit the Dual.
Dear Capt,
It is an impossible task to keep specifications on every turntable manufactured in the world, we cannot offer specific cartridge recommendations based on the turntable model. So to find a compatible phono cartridge for your turntable, you will need to know the cartridge mounting method and the tonearm tracking force range.
Unless the turntable is very inexpensive or very esoteric, the cartridge mount will be one of the following two types:
1) Standard Mount - by far the most common
Two screws, half an inch apart, thread through the cartridge body to secure it to the headshell, which then plugs into the tone arm.
2) P-mount - Primarily on Technics brand turntables
The four prongs at the back of the cartridge plug directly into the tone arm. A set screw goes through the side of the cartridge at the back, to hold it in place on the tone arm.
The other important turntable specification is the tracking force range of the tone arm. This is typically given in grams, e.g., 1 to 4 grams tracking force.
Using the mounting method and the tracking force as your guide, look at the Shure line of phono cartridges. In descending levels of sound quality, we have the following phono cartridges available:
Cartridge - Application - Mounting type
M97XE - audiophile - standard
M92E - versatility - both
M78S - 78 RPM - standard
The N78S replacement stylus will work in any of the above cartridges, providing them with wide-groove / 78 RPM record playback capability.
All DJ cartridges are standard mount, but these are not recommended for home audio use.
For more Info,pls visit the following
Based on the desired, I wd advise the INR pricing.
Rgds
Neeraj Chandra
Director
M44-7 is a DJ cartridge. Very high output of 9+mV. Perhaps one of the highest output, if not THE highest, output cartridge.
In fact I never play my Pioneer PL200 more than the 2nd or 3rd notch of the pre-amp. It's that loud! It has a very good bass. This cartridge is supposed to be a very good tracker since it is designed for jockeys who must scratch! It has rarely skipped in my system.
The M97xE is supposed to be the replacement for the V15, although there are folks (way too many, in fact) who say they are not a patch on the V15s. The V15s were discontinued due to the unavailability (or was it rarity or costliness?) of a material which was used in making the stylus. It was a living classic and now even more desirable as it's been discontinued. And opinion is further divided as to which was the best version. Some swear by the Type III whereas others do by the Type IV.
Joshua
Hi Capt,
M44-7 : 2800/-
M44-7-H : 4000/-
M92E : 2200/-
M97XE : 4800/-
You can by Shure M97xe from amazon in $54 free shipping to US.You can use shop and ship service for India.
Amazon.com: Shure M97xE High-Performance Magnetic Phono Cartridge: Electronics
Sachin
Sachin
Hey Sachin,
In spite of my reservations of ordering through net, I tried ordering the item since the cost difference appears irresistible. Alas, when I tried checking out, it says, the item cannot be shipped to the given address (My Indian address)
Looks like I have take the help of my US cousin again.
Rajesh
Yeah Sachin, I saw that link last night too, so people have a choice & can decide to buy from wherever they want.
Hey Sachin,
Rajesh
Capt, you hit the nail on the head :)
Wish we all had some relative/good friend staying in these places where the deals are really good:ohyeah:
Hey Sachin,
Rajesh
Captain you can use shop n ship service.They will charge only $10 for shipping to India.
SHOP N SHIP : http://www.hifivision.com/hot-deals...-uk-toooooo-much-cheaper-than-borderlinx.html
Sachin
Hey Sachin,
Rajesh
Hi capt,
I ordered my Shure MX97E from Amazon.com and paid close to 3.8k i/c shipping. It reached me safely, and performs very well.
N.Murali
