Which DVD Player is supporing USB Hard disk ?
ArvindG
mumbai
I want to buy DVD Player which should support playing from USB Hard Disk.
In Mumbai
I dont require Blue Ray player or so on Just simple one
Most of the dvd players and even bd players won't support ntfs formatted hard disk and pen drives. Also there will be size limitations as well. Some dvd players will support only upto 8GB or so. I would recommend a hdd media player instead of dvd player. With models like kaiboer you can add an external usb dvd drive if you want dvd functionality.
now a days most of the dvd players support usb hard disk
you can get samsung, sony, pioneer anything you and if you want to go higher on budget you can get denon, cambridge etc
True.. but most of the DVD player (or may be all of them) dont support HD movies play thru USB.. like i bought this Sony DVDp few months back and tried BRRips but it cudn't play it.. then i had to return it and bought Sony BRplayer.. So before making purchase make sure you check all your files playing on the DVDp.. :)
DVDp will support DVDRips thru USB..
Happy hunting...!!
I think it is better to wait and buy BD in place of DVD player as you can play HD Movies through USB and normal music files........always go for player which support NTFS......future proof.......8-))
Thanks all Hi-Fi-Visionary Memebers for your quick responses
Your suggestions are the great help for me.
I will share my experience after buying the convenient product.
