Which is best suitable technology for the older people/lg 3d denger guidlines
gappa
nashik
As you know the watching a tv is create eye related problems to the older people. And if other complications like diabetic present then dont ask.
I want to know on personnel experience what is best technology ( plasma, lcd or led ) for them
I have not considered 3D technology because it not recommended to them. I just gone through LG 3d cinema 47LW6500 and surprisingly LG have given lot of pricoshans list. I really appreciate their effort.
47LW6500 - 47 Inch LED LCD TV - Cinema 3D TV - Smart TV - LG Australia
Just press on
(((What You Need to Know about Televisions)))
Please note that this information is available on Australian web site and not on Indian
This is very seriously taken by Tv manufacturer .Some of you might have remember Samsung introduced tv long back .while watching that your brain waves and blood presser get cooled down.( it was 10 years back I even not remembered all the things)
LG 3D Viewing & Safety Guide
Please read the following important viewing and safety information before using the 3D imaging function on your TV.
CAUTION - WHEN VIEWING 3D IMAGING
Viewing Guide
When a TV can display in 3D when the TV is connected to a compatible device, such as a Blu-ray 3D Player. You need such a device to watch the TV in 3D. The 3D TV displays two separate pictures, each formatted for each eye. The viewer needs to wear 3D glasses in order to see each of these images in 3D format.
- To watch the TV in 3D, you must put on your 3D glasses. For best results, you should wear LG Brand 3D glasses. The 3D imaging may not display properly when using another brand of 3D glasses. Please see the 3D glasses manual for instructions on how to use the 3D glasses.
- After powering on the TV, a few seconds may be needed for your TV to calibrate.
- It may take a moment for you to see the 3D imaging if you look away from the TV and then revert your eyes back to the 3D program.
- The TV may flicker slightly if the 3D imaging is displayed under 3 wavelength lamp fluorescent light (50 Hz~60 Hz) or around windows displaying natural light. In such instances, it is recommended to turn the lights low and/or block the sun light with a curtain.
- If there is an obstacle between the television and the 3D glasses, the 3D imaging may not display properly.
- Do not use the TV in close proximity to other electronic equipments and IR equipments.
Safety Guide
- When viewing 3D imaging, watch the TV from an effective viewing angle and within the appropriate distance. The appropriate angle is 120(when the viewing distance is 2m (6.5 ft)) and distance is 2m 7m (6.5ft 22.9ft). If you exceed this viewing angle or distance, you may not be able to view the 3D imaging. Furthermore, the 3D imaging may not display if it is viewed while you are lying down.
- If you watch the 3D imaging too closely or for a long period of time, it may harm your eyesight.
- Watching the TV or playing video games that incorporate 3D imaging with the 3D glasses for a long period of time can cause drowsiness, headaches or fatigue to you and/or your eyes. If you have a headache, or otherwise feel fatigued or drowsy, stop watching the TV and take a rest.
- Pregnant woman, seniors, persons with heart problems or persons who experience frequent drowsiness should refrain from watching 3D TV.
- Some 3D imaging may cause you to duck or dodge the image displayed in the video. Therefore, it is best if you do not watch 3D TV near fragile objects or near any objects that can be knocked over easily.
- Please prevent children under the age of 5 from watching 3D TV. It may affect their vision development.
Warning for photosensitization seizure:
- Some viewers may experience a seizure or epilepsy when exposed to certain factors, including flashing lights or images in TV or video games. If you or
anybody from your family has a history of epilepsy or seizure, please consult with your doctor before watching 3D TV. Also certain symptoms can occur in unspecified conditions without any previous history. If you experience any of the following symptoms, immediately stop watching the 3D imaging and consult a doctor: dizziness or lightheadedness, visual transition or altered vision, visual or facial instability, such as eye or muscle twitching, unconscious action, convulsion, loss of conscience, confusion or disorientation, loss of directional sense, cramps, or nausea. Parents should monitor their children, including teenagers, for these symptoms as they may be more sensitive to the effects of watching 3D TV.
Risk of photosensitization seizure can be reduced with the following actions.
- Take frequent breaks from watching 3D TV.
- For those who have vision that is different in each eye, they should watch the TV after taking vision correction measures.
- Watch the TV so that your eyes are on the same level as the 3D screen and refrain from sitting too closely to the TV.
- Do not watch the 3D imaging when tired or sick, and avoid watching the 3D imaging for a long period of time.
- Do not wear the 3D glasses for any other purpose than viewing 3D imaging on a 3D TV.
- Some viewers may feel disoriented after watching 3D TV. Therefore, after you watch 3D TV, take a moment to regain awareness of your situation before moving
