XBMC better than Foobar via WASAPI for stereo?
BLASTO
Hyderabad
Hi Guys,
I setup my HTPC recently.
I have installed WASAPI drivers for the card (Esi Juli@) and am using it to send digital signals to Musical fidelity M1 DAC via coax.
There is difference between the sound when played the same song from Foobar and XBMC using same drivers.
I just tried XBMC because file management in foobar is pretty hard comparatively.
It turns out, In my setup XBMC is sounding richer and more dynamic than the foobar while the whole world says the opposite. Even the volume is a bit higher than the foobar (full volume).
Does anyone have similar experience?
I wonder if foobar's performance can be improved somehow. Honestly I wouldn't have cared if I have used only foobar but since XBMC is sounding better, it makes me wonder if there are any tweaks in foobar that I did not make.
For the record,
Equalizer is off in both (I dint even figure out an eq in XBMC)
Output set to WASAPI SPDIF out Juli@.
Played directly frm audio CD from DVD drive (did not build lossless library yet)
Both are latest versions downloaded from their respective websites. (had updates as late as a month ago).
One last thing,
When I set the output to WASAPI Analog Juli@ in XBMC, there is digital signal sent through Juli@ coax much to my surprise and it is as better or even slightly better than direct digital WASAPI out.
All the above differences I am sure will not be perceivable through double blind test to me I guess.
Iam leaning towards dumping Foobar for XBMC. I anyone hears perceptible difference in favour of Foobar, let me know if I missed anything.
P.S: Man, XBMC amazes me. Any number of youtube videos would not have set me up for the spectre it is. Transparency skin is a Killer!!
I prefer the xbmc Linux version with ALSA,
If you are on windows, make sure of this
Replay gain off
Cross fading off
Menu sound off
Output device & pass thru device same
Make your jui@ default card with preference and shared sample rate.
Most important keep your digital volume in xbmc full do not adjust
There are many more tweaks which can be done via advance settings xml
Now your on bit perfect
It's pity that many are blind folded towards foobar.
Oak
is it a good idea to make it the default audio device? system sounds would get mixed into it which means your audio will go via a mixer software?
IMPO, foobar is way overrated (YMMV). Once level-matched with WinAmp and all processing defeated, there is virtually no difference between WinAmp sound and Foobar sound. I have spent 100+ hours doing A/B between Foobar and WinAmp, couldn't hear a difference. But that was after I level-matched them. Usually Foobar output is 4-5 dB higher than that of WinAmp. Its quite obvious Foobar sounded nicer with default settings.
Try level-matching Foobar and XBMC before drawing a conclusion. Louder almost always sounds more detailed and nicer.
Congratulations blasto. Please post pictures of your htpc build. Which version of xbmc are you using?
The released version.
11 I think.
There was a Beta-2 which I dint download since I found small glitches in the released version itself.
I too heard only few songs. Will try others and conclude.
BTW, the eq of foobar is very bad. Anyone succeeded using it? Cuts of lots of frequencies without improving anything.
May be the stock equalizer is bad but I have these presets downloaded from this site. And these presets are good and you can use it default or change to your liking. I am using Foobar2000 over ODAC to my 571 receiver and it sounds very good. I tried the Dharma edition of xbmc and it was very bad not sure about the latest version which has the AE (audio engine).
XBMC V11 is Eden and is the current stable one. The new version 12 called Frodo is in beta state and I'm using it. It supports HD audio passthrough.
Volume controls are F8 - mute, F9 - decrease and F10 - increase.
What's the point, when you are looking for bit perfect raw audio, why do you want to use resampler dsp, it will process sound and send to external dac.
Send raw signal to dac and let the dac do its duty.
Oak
I know what you say is ideal, but at least to my ears it did make a difference making songs heard better. I cannot confirm whether it adds coloration but worth trying if someone has not tried already. With XBMC 11 (HD Audio Patch) set with WASAPI the sound was blunt in comparison with foobar.
Foobar + SoX resampler
Yes I have this combination and it sounds very nice/crisp/clear/neutral to my ears over the ODAC. Now a days I listen only to the Foobar2000+WASAPI+SOX-Resampler+ODAC+Yamaha 571+Direct --> Yamaha NS-F140 floor standers.
Me too in similar setup, and I have forgotten using my sub for music.
