Yht-185 Or Av+speakers(rx-v361+ns-p110)
tinny9
Patiala
Hi... it's me again........................ budget=25k
i had now managed to narrow down my choices
there are two options available to me, both are of YAMAHA:
1. buy HTIB YHT-185/195
HTiB YHT-185 : YAMAHA Audio and Video
2. buy AV Recievor RX-V361 + set of speakers NS-P110
Yamaha Electronics UK Ltd
some sellers told me that 2nd option is better and some says that first one is better. On paper their technical specifications are same. both are same priced, 2nd option is marginally expensive. So i am confused.
if u happen to tell me to buy the first option then please tell me aslo whether to go for YHT-185 or YHT-195. i am getting at the same price.
Home Theater in a Box YHT-195 : YAMAHA Audio and Video
ur replies are priceless.
thanks and regards
tinny
