Zidoo X10 5GHz WiFi Hotspot Speed issue
HDTV1080p
kolkata
I have plugged the LAN cable to the gigabit port and then enabled the WiFi hotspot in 5GHz band. Although, the Ethernet speed is showing the full speed (80 mbps) but the 5GHz WiFi is showing 50-55 mbps maximum. The signal strength is showing as "Excellent" yet it is limited to only 50-55 mbps.
The "connection speed" is showing as 96 mbps. For 5GHz, it should few hundred mbps at least.
What setup I need to change here?
