1 sub, 1000 questions - placement and so on
pls share a photo, only then you will be forgiven for posting in this thread :)
Here you go with the picture..
Here is the link to the picture. I am not sure why the picture is not visible after I posted it.
If you can see I have removed the sony hifi system from the right with its speakers and shifted them to my master bedroom. So I have lots of space empty in the corner. Now the people can do the needful in the placement..
where exactly do you wish to put the sub in here?
Do you see the sony hifi system+samsung woofer. I have removed them and that place is empty where I tested the jamo sub 200 for about 30 min and then removed it and placed on the floor.
Hi anm
Any idea about the placement of my sub..did you get the place what I was referring to..
yes I got the place. There is so much stuff there that it may rattle. But you can give it a try and see if you like it there.
I have removed the sony music system as well the sub woofer of samsung ht. So that place is right now with only tv and energy satellites. But as you said rightly when I increased the vol the whole area started rattling. So will try to find another place on the floor.
also there is lot of stuff in those almirahs - that would rattle. Floor is always a good idea. My subwoofer walks on the floor. On a table top which is not very rigid, it would jump :)
