Hello All,
After the 5.1 build with MTM's and Bookshelf's build with peerless speakers and dayton tweeters.
This time I wanted to raise a bar myself in the field of Audio and DIY.
So I have taken up the project to Clone the Econowave Design. I named this as "BLITZ".
And as always this time as well my mentor is Goldy Rathore, the design was also suggested by him
. Thanks for your help Goldy Sir(Really lot and lot of help) But still need a lot of help to close the project successfully.
The goals of selecting the design:
1. Constant directivity.
2. Keep the build expenses to least possible extent.
3. Use locally available parts in hyderabad.
Couple of sites on the Econowave design:
http://www.gedlee.com/downloads/directivity.pdf
Gainphile: S15 - Econowave DSP
Red Spade Audio: Introducing the Econowave speaker
Drivers used:
1. Compression Driver - P Audio thailand BM-D450S(Rs2000)
P.Audio | BM-D Series : BM-D450S
From Pro Audio vision in Paradise Sec'bad.
2. Ahuja 12 Inch Woofer(MID) - L12 - MB200(Rs1900) (New but same specs as its predecessor (L12 - MB150).
Ahuja Sound Solutions
From Ahuja Dealer in Koti.
Waveguide: Conical wave guide. The clone of JBL horn. Similar horn was copied by pyle and now in india we can see with dynamite for Rs.1000/-
DM 6512
But still i got the wave guide in hyderabad gujrati galli market made of plastic for Rs.500/-
Will keep you posted on the progress.
Thanks,
Yashwanth
Drivers used:
DM 6512
Thanks,
Yashwanth
