46-47" LCD Sony vs LG Showdown?
huntersingh
knp
Im getting for 83K either of them
Sony KLV-46V550a - 46"
LG 47" LH50
WHich one should i buy
LG does have 200Hz, 2ms response time and other features which they brag about, but SONY has its brandname.
Which one would be a better buy ? Expert help will be great
well the LG has 100hz + backlight blinking,but they call it 200hz.only true 200hz tvs in india are samsung B740 , B8000 and sony Z450A,Z550A.
the LG is slightly better in motion due to 100hz,but still lacks the contrast of the sony v550A or even a samsung B550.nor is its image processing as good as the other two especially in SD.
the LG is slightly better in motion due to 100hz,but still lacks the contrast of the sony v550A or even a samsung B550.nor is its image processing as good as the other two especialy in SD.
LG's contrast ratio is 150000:1 Dynamic , but i dont have the figure for Sony
i assume 150000 is quite godo ?
well don't go for the contrast ration quoted in website and brochures.its the dynamic contrast,which is of no use,like PMPO in audio.
the real static contrast if u go by the ANSI method the best of LG lcds wont cross the 1000:1 and the best of the sony lcds won't cross the 3000:1,without LED dimming.
Thanks for your help adder. Its of much use.
SO i should buy sony right ? Im leaving my decision to you know as im impressed by your knowledge.
Also since im naive to this.. can you suggest any other lcd .. 46"+ under 95K which i should buy ?
look forward for your advice again
well if it is SD that is important the V550A is a excellent choice,however under 95k u can consider the samsung 46B650 it does have 100hz,whether u can get under 95k depends on ur bargaining skills.
@rajapraveen80
depends on how u measure it.
Kindly rate the following in order of preference of buying ?
a - Sony KLV-46V550a - 46"
b - LG 47" LH50
c - Samsung 46B650
d - LG LED TV 47LH90
help much appreciated
b - LG 47" LH50
c - Samsung 46B650
Each of the above will have +'s & -'s. It really depends on your requirements. If you ask 4 different individuals to rate, you may get as many ratings. So it is very individualistic.
However, considering PQ, SD signal upscaling & Contrasts are most important criteria, the following would be my take from the list you provided:
SONY V series
SAMSUNG B650 / LG LED
LG LH50
However, if VFM is criteria then LG LH50 / LG LED would lead. The USB port on LH50 can play DivX movie formats. Followed by Samsung B650 and then the Sony V series.
The SONY V series does not have the 100 Hz motion flow technology found in W series & up in Sony models. However the other 3 LCDs you mentioned have 200 Hz True Motion (LG) / 100 Hz Motion Plus (Samsung).
