6 1/2 inch mid bass/woofer
hydrovac
Hyderabad
I am looking for a pair of mid bass/woofers, with close to similar parameters.
Re 3.8 ohms
Fs 41 Hz
Qms 3.86
Qes 0.32
Qts 0.30
Vas 20.09 lit
Any site, other than loudspeakerdatabase offer specific size based search?
If it’s a mid bass, Le might also be a bit important to specify. If you don’t mind, what is your intended application?
Hello. While you may not get the exact same specs, you might be able to get a driver that models similarly in the same Vb and box tuning.
if you could share the box dimensions and tuning ( as simple as taking an impedance sweep with current driver seated in cabinet, perhaps we might be able to suggest approximation which will serve as well.
I have got a pair of drivers . Based on what yogibear and others said, they are mid bass drivers 12 inches. Interested?
You can check my subwoofer thread for further details.
The enclosure volume is 9.0 lit
port was originally tuned at 55 Hz... this is for a two way BS if that helps.
Oh! my bad... i should have mentioned the size of the woofer... it's a 6 1/2 inch long throw woofer.
I have a
Re 3.8 ohms
Fs 41 Hz
Qms 3.86
Qes 0.32
Qts 0.30
Vas 20.09 lit
I have a Pair of SB Acoustics SB Acoustics SB16PFC25-8 6 Drivers, I bought to replace one of my old Aiwa speakers.But it was not matching to the Tweeter hence its resting in Shelf.If interested kindly ping me.
I have used one drivers for testing (Probably for a Hour) and other is still in Box, unused.
I have a
Thanks,
i already ordered the above mentioned woofers.
