aniruddha82
Any good ideas for enclosure for this PCB and transformer? ( I already have heat sink)
After doing some online research I came to know that Steel enclosure is best as it provide shielding, but at the same time it is difficult to work with, I can not do drilling etc etc with my home tools.
Aluminium is easy to work with, but not as easy as 6-8mm MDF plywood. I am inclined towards using plywood , as it is the easiest. But I understand it is not the best to choose for amplifier enclosure.
I see that diyaudiocart have a very nice amplifier enclosure, but unfortunately it is beyond my budget for this project.
Do you guys know any other cheap alternatives for amplifier enclosure which will require least effort? I can compromise on the quality a little bit to keep the costs low.
Thanks in advance for help.
