Active n Passive Sub
Vishu_fbd
NCR
I am based in faridabad and planning to buy a HTiB system. I have a budget of 30K and have zeroed in on onkyo 590, yamaha and sony ddw800 system.
Onkyo has 140W RMS passive sub and yamaha & Sony hv active sub. Sony and Onkyo retail at 30K (after discount). I have read that onkyo is better in clarity than sony however the 570 model has now been discountinued which had an active sub. The new 590 has 40 W more power but is a passive sub with other spec almost the same.
I want to know more abt yamaha htb and its dealer detail in delhi so that i can decide the best of the lot.
If anyone can shed his/her valuable inputs?
Thanks in advance,
Vishu
I would definately recommend you to go for the HTIB system that provides a active sub!
Without doubt the active sub would perform much better in a HTIB setup.
Listen to all the systems before buying.
The Sony DDW880 has HDMI which is a big plus (for the future). Do the others have it as well?
Has anyone an idea as to how good these are for music?
Definetely an active sub. I have forgotten the name of the dealership but there is a yamaha dealership in lajpat which carried the entire range of subs when i went last. ill get back to you with a name
Considered Boston acoustics...there is a dealer in west delhi somewhere which carries 4-5 models .150-500 RMS. THe entry level one is around 14k-15k and has a 8 inch driver.
cheers!
The most effective low priced sub I have seen were from Jamo and Polk Audio. They are not too difficult to find in Delhi/NCR region.
put aside some decent money for a quality *active* sub, definitely worth & give decent rumble to your cinema room
