Advice speaker system for a Showroom
Any AMP to be bought separately or just direct plug-in to the laptop head phone port ?
Yes, you need a amplifier to run these speakers, you can use any amplifier as per your budget.
For direct plug-in you need active speakers set (which don't need amplifier) are like logitech, F&D, Creative etc with inbuilt amplifier and can be used with any source like Laptop, iPOD, Mobile etc.
You advising 1 set of Acoustimass 5 or 2 set of Acoustimass 3?
Yes, if you can stretch your budget a bit.
You can search on OLX and Quikr, there are many options in used ones.
Also another suggestion is go with F&D 2.1 speakers (2/3 sets, like Bose Acoustimass 3) it will cost you very less and will work as what you want, already suggested how you can place 2 sets in your showroom. The quality of sound in F&D speakers is not too bad, and you are not going to play at very high volume, if your source is good then definitely you will be satisfied.
Have a look on products and their reviews here.
Which 2.1 F&D model do you suggest from the given link ?
Will i require an amp with F&D as well ?
Thanks a ton
Amplifier not required for these F&D speakers, you need to input the signal only either it is Laptop or iPod or iPhone. You can check F&D F680 See website too.
If you buy three sets, and place them on different locations. You just need to plugin the signal from source in all 3 sets and fill your showroom with sound.
