Airplay issues in Denon AVR 1912
vj_pavan
Hyderabad
Ive recently got a Denon 1912. It has a few issues with the iPad 2 controls.
1 Airplay: Frequent dropouts
2 Denon Remote App: Worked on Day 1, says connection failed now.
Note that internet radio works perfectly, so does the Web app. So, its clearly not a network issue with the Denon.
Im using iOS 5 on the iPad. Read online about people having problems after 4.2. I wonder if its my Wireless G router which cant seem to be streaming data fast enough?
Any ideas appreciated.
Fyi guys, upgraded to a Wireless N router... Airplay works almost perfectly now! Dropouts are as low as 5%.
Just hoping that Denon works out its issues on the Remote App soon!
SOLUTION
SWITCH ROUTERS!!
i simply switched to a basic wireless g router from my fios wireless n router and now everything works perfectly! my iphone, ipad and macs with itunes see my denon avr-1912 as an airplay device and can even wake it from sleep!
i tried to avoid this for as long as i could, but i would recommend you dont waste time like me and try this first!
