D
Deleted member 38504
Guest
Ok so basically Redbook format is a regular cd we play? Or is that not Redbook? Is it true that r2r or NOS are best type of dac for connecting to a cd player?
I'm sorry if this is off topic, but what exactly is a Redbook cd/dac? Can someone explain without too much technical detail.
Also, if I play a track on Spotify which is a low resolution track, and I connect my streamer to a DAC. Will the dac be able to convert this same low res track to a high resolution track?
Or am I off track?
Whether you like a r2r dac or more modern delta sigma type DACs is a matter of preferenceOk so basically Redbook format is a regular cd we play? Or is that not Redbook? Is it true that r2r or NOS are best type of dac for connecting to a cd player?
Audio CDs are Redbook.Ok so basically Redbook format is a regular cd we play? Or is that not Redbook?
Not for me.Is it true that r2r or NOS are best type of dac for connecting to a cd player?
+1 to that..so easy to get lost in the theory while the prrof is all in the implementation.Audio CDs are Redbook.
Not for me.
One can't, and should not, generalise that non oversampling ladder DACs are the best sounding. There are good sounding delta-sigma DACs. There are bad sounding delta-sigma DACs. Same applicable for ladder DACs.
As with TVs, quality of upsampling matters a lot. Plus upsampling is a divisive concept - not everyone likes it. Generally, hear before you buy.Jai thanks for clearing that up. The analogy of the 480 to 4K helped clear my doubt a lot. Upsampling is still better than nothing right? I mean I’d rather look at a 480 on a 4 k tv rather than on a SD tv, right?
Ha ha.. and I downsample to 16/48 if it is a Hi Rez fileI have disabled the upsampling feature on my DAC. I prefer the music at its native resolution.
Actually never tried it. What difference do you perceive?Ha ha.. and I downsample to 16/48 if it is a Hi Rez file
Just as an analogy (though not close) when I compare a track on its original CD master with the LP/spool, though the CD has a better dynamic range, the LP sounds more fuller. CD may sound cleaner, but somehow the pure analogue has a slightly better emotional content and naturalness to the instruments.Ha ha.. and I downsample to 16/48 if it is a Hi Rez file
Yes, this is so true. You guys should listen to the new acoustic portrait dac which uses a delta sigma chip. I think it is the ess 9028. Lovely implementation.+1 to that..so easy to get lost in the theory while the prrof is all in the implementation.
Absolutely.And Analogue definitely has a more emotional connect, but I am afraid we will derail this thread with this talk
Even if it is 24/176 or 24/88? Since they are not multiples of 48...there will be needless interpolation...Ha ha.. and I downsample to 16/48 if it is a Hi Rez file
that goes to 44.1Even if it is 24/176 or 24/88? Since they are not multiples of 48...there will be needless interpolation...
