Any High End AV Receiver with Universal Power Supply from US
santy1976
Can anybody advice me on buying a high end AV receiver with universal power supply.I had come across one of the players some days back on the net but couldnt recollect it now and I havent bookmarked it as well.. Tried googling it a lot but couldnt find.. Thought might some get some advice from you guys.....
Features Needed
Network Support
AirPlay
HDMI
etc
what do you mean by high end. most of the good brands (denon, yamaha, marantz, onkyo, nad etc) come with a switch to move between 110 and 220v. what speakers do you want to pair it with. do you have a plan in mind or just buying an amp because an opportunity has come your way.
Yep I would like to have anything that has been released recently nothing 2 yrs back.. i dont mind be it NAD / Yamaha /Onkyo / Anthem / Marantz and I would like to buy it from US only due to the cost factor.. As far as speakers are concerned i havent made a decision on the same but since u guys are pro's in this area can you please suggest me which one to go for...Not that I'm rich but I dont mind buying little expensive speakers . My requirement is for Music and Movies only as of now and prbly games later on...Hope this helps.. Thx in Advance buddy
its best that you work and buy towards a plan. atleast a budget and keeping in mind room size. i assume youre looking for a surround sound setup. as per my knowledge most receivers in usa now come with dual voltage switch. check online or with a store whether a particular model comes with the switch. you will need an amp with power output to match the speakers that you pair it with so you will need to come to a basic decision on what price range youre looking at
Hi santy1976, (AKA the other santy on our forum :D)
why don't you contact Ashish of Avenue Sounds??? He has the Yamaha 1010, 2010 & 3010 + Denon 2112, 2312, 3312 in stock at the moment. He will also include the step down in the price. So do give him a call & check 'em out, as it saves you the hassle of importing the AVR from US. We had a HT meet yesterday @ his premises & we thoroughly appreciated him being more as a friend than a dealer.
