GeorgeO
Folks
I need a pair of speaker baffles in solid timber to be cut for an MTM speaker project. The piece of timber will be about 10 inches wide and just under 2 feet high. I will get the cut marked out clearly and take it to the wood working unit for the cutting to be done neatly.
The midwoofers are about 180mm dia and the tweeters around 100mm, with the mounting depth about 3mm for the mid and 9.5 mm for the tweter( the tweeter has a custom speaker baffle plate that is much thicker than the standard SS baffle plate.
Thanks for any assistance.
P.S. The speaker enclosures are ready but the carpenter botched up the timber baffles by cutting them manually and I am not hunting for some wood which I should get in the course of the next day or two.
