AVR vs Stereo is a topic that has been debated many times on internet forums. My reason for taking part in the discussions is that only when there are arguments for and against, will it help our members to arrive at decisions based on their needs. I would have liked more knowledgeable members to come out with their views on Receivers as the Stereo camp has quite a few knowledgeable members in our Forum.
It is not uncommon for many of us to buy a TOTL Receiver and then wonder if investing in a power amp would bring in drastic changes to the sound or if adding an integrated to the fronts would bring in drastic changes. Occasionally, I myself have had thoughts on these lines.
But as our hobby can get very expensive, I feel that money should be invested in areas that will bring in the best result especially seeing that most of us don't have the experience or ability to identify that perfect sound.
Am rambling. :lol:
Please take over Receiver experts.
The reason why I posted is mainly because most AVRs in the entry to mid level segment (not $2k TOTL AVRs) do indeed have poor/weak power amp sections. I speak from personal experience. My Marantz slimline AVR was doing okay but really not great in driving my stereo floorstanders. When I used preouts from the AVR to feed it into an integrated/power stereo amp, the sound quality improved quite a bit.
I also see a lot of comments in stereo vs AVR discussions where only high end AVRs are considered in the discussion. My point is - any discussion should be done at certain budget ranges. It is pointless to mix and match - and it also pisses me off when reviewers do that. They will take a $200 speaker and drive it with a $10k amp, or the other way around. What's the point??
If you want to discuss high end AVRs and if it makes sense for stereo, perhaps it would make sense to do a face-off between:
1. A good quality high end AVR playing stereo music - priced at about $2k
2. An entry level AVR ($300-$500) with stereo preouts to a 2-channel power amp or 2 channel integrated ($300-$700) - total cost in the range of $700-$1k
3. An entry level pre-processor like Emotiva MC-700 ($600), paired with a multi-channel value-end amp like Outlaw Audio Model 5000 - 5 channel power amp ($600) or Model 7140 - 7 channel power amp ($1100) or Emotiva A-700 - 7 channel power amp ($600) - total cost $1200 - $2k
Just my two cents.
The discussion I am proposing here is not if Stereo amp is better than an AV Receiver. Lets face it. If someone is going to listen to stereo only, he is not going to buy an av receiver.
AV Receivers, if you ask me are clever designs and clever compromises. They are aware that in a 7 channel receiver, not all 7 channels will be playing equally and drawing equal power from the amp. The greatest advantage of the Receiver is its ability to send the most demanding parts of the soundtrack (movies or music) to the sub. If configured correctly, most loads dipping to 4 ohms will be handled by the sub, thus taking the load of the receiver to a large extent.
This has to be kept in mind while thinking of the benefits of adding an integrated / power amp to the system.
Your thoughts please.
Always stereo amp will be better route unless you want to use existing avr, then adding power amp will be good.Reviving old thread.
Your thoughts on following for stereo 2.0 setup. which one is better
AVR (low end)-> front pre out -> 2 channel power amp ( example marantz nr 1508 + marantz 7025 )
OR
Integrated stereo amp ( example marantz pm 8005 )
Well you cannot make a blanket statement saying a 2 Channel Integrated is better than an AVR. For example a good AVR like the Bryston SP3 which has Class A output stage and is fully differentially balanced from Input to output stage will beat a mid priced 2 Channel Integrated. Also the upper end prepress offer Room Calibration and multichannel processing. However if you are investing in a high-end 2 Channel Integrated like Audio Research VSi75 then they are in a different league. However if your speakers are power hungry then most integrated amps will not be able to play loud without distorting.Hi everyone. Pardon me if this question has been asked before in this forum.
After learning that a 2 Channel Integrated Stereo Amplifier's? superior performance over a multi-channel AVR for obvious reasons, I wanted to know what do you prefer for your music?
Do you prefer quantity or quality? I know it's an apple vs oranges comparison but would really like to know.
Do you like listening? to your music in AVR or do you have a separate Integrated Stereo Amplifier for it? Or do you have a Stereo Home Theatre setup? [emoji4]
Sent from my Redmi Note 4 using Tapatalk
