Best 5.1 HTIB system package under ₹50,000 (strict budget)
In my view its the right decision.
You can always add more later.
On a limited budget, rather than HTIB, I would reccomend buying good equipment that will last, item by item, as budget permits.
This way you get a system that will last many years.
My thoughts on sequence of purchase.
1. AVR receiver + good bookshelf speakers ( theYamaha you have mentioned seems fine).
This itself will give you a massive upgrade over TV speakers.
2. A good sub, when you have the money.
This will upgrade your system from 2.0 to a 2.1 and give you most of the fun of a home thetre system.
3. A matching centre speaker, when you have the money.
4. Surround speakers. These need not be expensive.
You can space this out over months or years.
Just my thoughts.
Taga Harmony TAV506 aint good?sorry but i am getting confused with your reply
Its fine.
All I am saying is, that on a limited budget, you need not buy 5 speakers all at once.
You can space out your purchases if required.
If you afford to buy all at one go, great.
